01-25-2009, 06:33 AM
Daniel_Chronos Daniel_Chronos is offline
Purchased singly in a thin case, surface label is red with the TDK logo, label text reads: "DVD-RW 1-4X Rewritable 4.7GB/GO" The disc itself is grey with the text: "TDK DVD-RW 1-4X 4.7GB DVD RW". Disc surface is blue/silver. On the innermost blue ring on the writable side of the disc is either "GO510" or "G0510".
ImgBurn reports the following about the media:
Disc Information:
Status: Empty
Erasable: Yes
Free Sectors: 2,298,496
Free Space: 4,707,319,808 bytes
Free Time: 510:48:46 (MM:SS:FF)
Supported Write Speeds: 2x, 4x
Pre-recorded Information:
Manufacturer ID: TDK601saku
Physical Format Information (Last Recorded):
Book Type: DVD-RW
Part Version: 3
Disc Size: 120mm
Maximum Read Rate: 10.08Mbps
Number of Layers: 1
Track Path: Parallel Track Path (PTP)
Linear Density: 0.267 um/bit
Track Density: 0.74 um/track
First Physical Sector of Data Area: 196,608
Last Physical Sector of Data Area: 2,495,103
Last Physical Sector in Layer 0: 0
Current Format Capacity:
Sectors: 2,297,888
Time: 510:40:38 (MM:SS:FF)
Preferred Format Capacity:
Sectors: 2,297,888
Maximum Format Capacity:
Sectors: 2,297,888
01-25-2009, 06:35 AM
These are good discs. I use about 10 of them myself, for weekly personal DVR purposes. At one point in time, these were on clearance at Walgreens in the USA for $1 each -- a great deal.
01-25-2009, 06:36 AM
Crap, I make a typo on something, and it's _got_ to be in the title, which can't be edited after the fact. Mutter mutter mutter
I fixed your typo.
01-25-2009, 06:37 AM
Whoa, that was such an awesomely fast reply to my post! I didn't even have enough time to comment about my title typo! Man, you just blew my socks off!!!!!
01-25-2009, 06:38 AM
I just happened to be online at the exact moment you made the post.
01-25-2009, 06:41 AM
They're currently on sale here at an "Everything for a Dollar" store in Vernon, BC, Canada, for, you guessed it, $1 (Canadian, which is about $0.78 to you guys down there, plus shipping... )
Given that high praise, I will plan on going down there tomorrow and picking a bunch of them up.
Thanks.
dvd-rw, tdk, tdk601saku
TDK-branded Ritek DVD+R DL media? admin Blank Media 1 03-26-2009 09:28 PM
LG branded media? admin Blank Media 0 01-07-2009 05:18 PM
How to upload samples to digitalFAQ server (FTP info) admin General Discussion 0 04-28-2006 09:13 AM
MPEG Editor Info: Womble MPEG-VCR vs MPEG Video Wizard vs VideoRedo mitch Edit Video, Audio 10 10-13-2005 04:50 AM
Any info about this (KWorld USB DVD Maker) stoogedog Capture, Record, Transfer 3 08-05-2005 09:59 AM
