11-17-2011, 09:17 AM
carlthulhu carlthulhu is offline
I'd like to buy a Blu Ray burner for my Mac Pro.
Apparently the Pioneer Blu Ray burners are incompatible with macs:
http://www.amazon.com/Pioneer-BDR-20...R18SXMB1C384I1
and this fellow says it doesn't fit anyway:
http://www.amazon.com/Pioneer-BDR-20...R29EFYXE0ET9IZ
Any advice for what Blu Ray burner would be best for a mac pro?
Thanks in advance,
Carl
11-17-2011, 08:15 PM
You'll probably have to use an external one. Apple is not Blu-ray friendly. (That was their choice, as a former HD-DVD backer.)
There's not even Blu-ray authoring software that I know of. So why put a Blu-ray burner in a Mac?
Edit: Encore CS5, maybe?
Lacie makes this for $350: http://www.amazon.com/gp/product/B00...SIN=B003D4OXCQ
Or instead of $350,
- Buy the Pioneer for $95: http://www.amazon.com/gp/product/B00...SIN=B004ILKH64
- And gut the $95 Lacie DVD external: http://www.amazon.com/gp/product/B00...SIN=B001P5C9S0
So ~$200 for the external Pioneer drive. That's what I'd do, if I really needed Blu-ray on a Mac tower.
Trying to cram a BD-R into a drive-unfriendly Mac just isn't going to be a pleasant experience.
11-17-2011, 09:12 PM
Exactly, I have Encore CS5 for authoring. I have a PC as well, networked to the Mac. I think I'll install the burner in the PC, and transfer the files from the Mac to PC when I need to burn. A temporary solution, as I can't imagine Mac going without a decent Blu Ray burner forever.
Thanks again for helping!
Carl
Advice(s) for a Blu ray burner monks19 Blank Media 3 09-18-2011 05:59 AM
DVD Burner jrnyhead Blank Media 3 01-17-2009 03:21 PM
Burner advice needed dannyboy Blank Media 4 02-07-2008 01:07 PM
DVD burner going bad???? MagnificentMarcus Copy DVDs, Duplicate, Replicate 14 08-09-2006 05:07 PM
Dvd burner help d.smyth Blank Media 3 02-15-2006 05:33 PM
