03-14-2023, 08:32 PM
hsm2010 hsm2010 is offline
Can someone explain whether it is better to record S-video from 8mm tape into OBS using i420 or NV12 color format. These are selectable on the "advanced" settings.
I want to preserve the color info coming from 8mm video thru a BlackMagicDesign Analog to SDI converter.
The S-video into the Analog to SDI converter uses a luminance cable and a single combined chroma cable.
8mm, color format, obs, s-video
Color issues in VHS video, editing issue after capture? billybatts Restore, Filter, Improve Quality 2 06-21-2021 07:33 AM
Video capture with horrible color noise bands? lzrplayr Capture, Record, Transfer 23 02-07-2021 04:34 PM
Basic video editing, color correction after capture? BOBcat76 Edit Video, Audio 1 02-06-2021 08:24 PM
What capture format should I use for VHS to PC? Mikeforest Capture, Record, Transfer 0 07-28-2018 07:57 PM
Color calibrating your monitor? (Seeing "true" color of your video captures) baywatch242000 Project Planning, Workflows 4 04-09-2014 01:30 PM
