01-16-2016, 03:20 PM
Mejnour Mejnour is offline
Hello,
I would like just to share some impressions about some gear that I recently acquired to help me with vhs tape capture.
Snell & Wilcox Mach 1 M.Sc
Mach 1 M.Sc can do many things manual
The Reduce noise feature is pretty good and come with a lot of tweaking option.
So far best noise reducer that I saw at the hardware level. I didn't compare to Neat Image but it
look in the same league....
Proc amp include luminance gain, black level, chroma gain and RGB legalizer.
And sure you have all the converting option that come with it.
For the Snell & Wilcox Mach 1 you need this special cable to goes s-video.
I think Snell and wilcox do many model with this noise reduction feature, so you may look not only
for the Mach 1 if you are looking for this feature...
Kramer SP-11D
Pretty complete Pro-amp with TBC. I use it mainly for it's ability to play with RED; GREEN and BLUE color but it have many others tweaking options. manual
I re-did a job with a noisy tape with those guys in serie with improved the result.
If you are able to get them cheap, that could be interesting alternative to add to your workflow.
01-16-2016, 06:18 PM
Goldwingfahrer's Avatar
Remembered
Kramer SP-11D
The issue with this Kramer we had here already times
http://www.digitalfaq.com/forum/vide...er-sp-11d.html
there is no consumer recorder of a clean and time-constant signal outputs.
You need either a broadcast recorder such Ex. JVC BR.Sx22 ........ or Pana AG-8700/8600/7750/7650
Or a good external TBC.
We had here in old Europe in addition to the Kramer SP 11D also devices from Snell & Wilcox tested [NRS50]
The Kramer and the Snell & Wilcox equipment have been built for movies from VHS ollen [S-VHS] recorder.
These devices expect a clean signal.
01-16-2016, 06:42 PM
I did not noticed this green line....anyway it look like it's in the overscan region...if so... it's no big deal
01-16-2016, 07:34 PM
Remembered
Green stripes, a different user was reported.
I have something not.
The head switch Noise [German = Kopfumschaltbereich] I cover with Avisynth or in Edius.
I wanted to write that consumer recorders do not provide a clean signal
the TBC in Kramer and also with the Snell Wilcox NRS50 can not do anything with VHS Consumer signals.
The Kramer SP 11D I use for color shifts and output via SDI
ProcAmp enough here the Canopus NX Map
Pictures of the NX I've shown here.
I turn the Snell & Wilcox .... race all customers away Because of the noise of the fan is too loud
01-17-2016, 06:29 AM
I always enjoy reading about what others experience.
01-17-2016, 07:30 AM
Remembered
Be Yes, humor has to
But sometimes that's a lot of testing work
not always you will be paid
God give me plenty of free time and even more brain
Here are some pictures from my archive
01-18-2016, 01:28 PM
Hello,
Here is some video showing that in my set-up, SP-11D and Mach 1 can be use with commercial VCR.
The footage is from 1981 from a conference speaker.
For Mach 1 NR feature, I used maximum setting.
Recursive Level= C off (chroma); Y high (luma)
Recursive Threshold = 7 (max)
Median Filter ON
Enjoys
JVC SR-W7 TBC OFF
Jumping video with ugly colors.
JVC SR-W7 TBC ON
Video stabilized, still a bit shaky and ugly colors
SR-W7 TBC ON + Kramer SP 11D
Video Jumping; Interference!? better colors
SR-W7 TBC OFF + SP 11D
Turning SR-W7 TBC off solve jumping problem, better colors
SR W7-TBC ON + MACH 1
Video is less dark; NR applied; video a bit shaky.
SR-W7 TBC OFF + MACH 1
Video is less dark; NR applied; video is stabilized.
SR-W7 TBC OFF + MACH 1 + SP 11D
Stable video with acceptable colors and exposure.
SR-W7 TBC is unique vs others JVC TBC, I decided to try with HM-DH40000 player where the TBC is always active.
HM DH40000
Video is stable; colors and exposure off...
HM DH40000 + MACH 1 + SP 11D honrizontal
HM-DH40000 TBC does not interference with Kramer SP-11D and Mach 1. In this case Mach 1 NR was apply below the horizontal line...
01-18-2016, 10:42 PM
Originally Posted by Mejnour View Post
better colors
That's quite subjective, haha.
I notice that both of the "pro" TBCs exhibit bending at the top of the frame.
01-19-2016, 06:30 AM
Hep customer is always right
In this case they gave me "the true wall color" and precise
Instruction for the face exposure of the speaker.
The were happy and I got paid...
01-19-2016, 11:28 AM
The HM-DH40000U internal TBC is a full frame system, it always outputs a stable continuous signal. An external full frame TBC isn't needed unless the source is copy protected. Its also why the S&W and Kramer boxes don't interfere.
01-20-2016, 02:32 AM
Remembered
Unfortunately this is not there in Old Europe
I always need a Full Frame TBC at the Snell and when Kramer
Posted by Mejnour
I would not get any money because
At first I would have tried a different recorder.
Image is blurred
Source filtered something see MP4
audiodelay one must also take into account
In the example [PAL] there are 80 MS
Best external USB video converter? Junior1s Capture, Record, Transfer 31 11-05-2018 09:41 AM
Digitalizing VHS tapes using NRS50 Snell & Wilcox? JMA92410 Capture, Record, Transfer 2 09-15-2018 06:13 AM
SDI capture from Snell & Wilcox Mach1 Mejnour Project Planning, Workflows 0 03-19-2018 09:49 AM
AVT-8710 dropped frames vs. Kramer FC-400, proc amp? milosz Restore, Filter, Improve Quality 11 05-09-2017 02:26 PM
Snell & Wilcox TBS24 for VHS to digital transfers ? lordsmurf Restore, Filter, Improve Quality 23 04-06-2011 03:17 AM
