12-07-2020, 12:46 PM
tsmithlorman tsmithlorman is offline
Hi all,
I have been tasked to install an audio filter preset for an end user. I'm not a sound forge end user so know little about the software itself. I was provided this website. http://www.digitalfaq.com/forum/vide...io-filter.html
I downloaded the preset mgr, installed it. Then I opened it, browsed to and opened the downloaded filter from that same URL, it opened. I then dragged it from the top window down to the bottom window, and the preset mgr app crashes. I've tried restarting and I've also tried it on a second computer that has sound forge installed and it has the same result.
What am I missing?
Thanks,
Tom
12-29-2020, 11:32 AM
- Which version of Sound Forge?
- What OS are you on?
- Did you run Preset Manager in a compatibility mode?
Sound Forge Preset Manager not taking plug-ins? colony Restore, Filter, Improve Quality 3 04-16-2019 03:45 PM
How do I use Sound Forge preset filters? Tafflad Restore, Filter, Improve Quality 5 11-03-2013 09:56 AM
Computer Crashing ishmot Computers 6 01-07-2006 02:07 PM
MMC Preset Times lantern Capture, Record, Transfer 2 08-05-2004 08:16 AM
