03-28-2021, 01:22 PM
EmielBoss EmielBoss is offline
My setup for capturing PAL Hi8 is:
Sony CCD-TR825E (TBC On) --S-Video--> ES15 --S-Video--> AVT-8710 --S-Video--> Pinnacle 710-USB --USB--> Windows XP/VirtualDub
The audio, however, goes straight from the camcorder to the capture card:
Sony CCD-TR825E --Component Audio--> Pinnacle 710-USB --USB--> Windows XP/VirtualDub
and is therefore three to four frames ahead of the video. If I route the audio through the ES15 as well, this difference disappears (which saves me some extra syncing steps). Is this detour harmless for the audio?
If not, can I use FFmpeg to delay the audio on the AVIs, or are there better alternatives for doing this?
audio, es15, sync issues
PAL-N with DMR-ES15 passthrough? Saporo Capture, Record, Transfer 2 10-28-2020 08:30 PM
Panasonic DMR-ES15 for capture? TotalSmart Capture, Record, Transfer 16 08-11-2020 07:43 PM
DVK-100, ES15, Daewood quality? LorettaTX Project Planning, Workflows 2 06-10-2020 08:31 PM
DMR-ES15 remote recommend? BarryTheCrab General Discussion 2 07-02-2019 05:38 AM
DMR-ES15 passthrough functions? homefire Capture, Record, Transfer 9 05-14-2019 12:59 PM
