04-24-2021, 01:16 PM
CarlEHL CarlEHL is offline
Send a message via Skype™ to CarlEHL
Hello all,
I've learned from this forum that there are at least 3 versions of HuffYUV (plain, MT & 64). I still confused about which one is the best suitable for video capturing with a Pinnacle Dazzle in my Windows 10 Home Single Language 20H2 Version, the OS is 64-bit and the 6-Core processor is x64 based.
I'm also confused about the HuffYUV version I have installed, I downloaded them 3 from here and it appears in VirtualDub as: "Huffyuv v2.1.1 - CCESP Patch vo.2.2"
So my couple of questions would be:
- Which version of HuffYUV is "Huffyuv v2.1.1 - CCESP Patch vo.2.2" and is it the right for my setup?
- If I should change it, which one should install instead?
Thanks beforehand.
04-24-2021, 08:53 PM
stymie stymie is offline
Huffyuv v2.1.1 - CCESP Patch vo.2.2 is for 32-bit software like Virtualdub 1.9.11. The 64-bit Huffyuv is for 64-bit software. The way I check to see what is installed is to open Virtualdub and select Video, then Compression...and see if Huffyuv is listed. Note: for Windows 7 and later, to install the 32 and/or 64 bit versions of Huffyuv, you have to install them manually as described in various posts in this forum. The Huffyuv MT version isn't recommended.
The following users thank stymie for this useful post: CarlEHL (04-25-2021)
Which Huffyuv version, how to install Windows 10 x64? Oakleaf Capture, Record, Transfer 9 04-26-2019 03:26 PM
Wanted: ATI All In Wonder card (PCI version) videonut Marketplace 2 07-21-2014 08:28 AM
ATI MMC version 8.8 best for AIW 9600 card ? pete Capture, Record, Transfer 1 03-21-2012 02:45 PM
