07-09-2021, 10:29 PM
Hi, I'm from Australia & I'm using my ES10 connected to my VCR & my USB live-2.
Capturing VHS tapes is fine but now I'm capturing NTSC tapes on my VCR & I've noticed a weird line near the top of every video & I'm wondering what might be causing this.
I've attached a photo, it's sort of a faint white weird line at the top of the video, you will see it just above the picture frame.
Does anybody know & also what NTSC capture settings are people using?
Thank you
07-10-2021, 12:06 AM
What standard the VCR is PAL or NTSC?
07-10-2021, 12:25 AM
It is a multisystem Pal & NTSC VHS player
07-10-2021, 12:33 AM
Panasonic NV-FJ600 Pal/NTSC 3.58/4.43
07-10-2021, 02:02 AM
Most likely part of the video, Some low end camcorders and VCR's do record weird patterns.
07-12-2021, 07:13 PM
FWIW, with NTSC it was not unusual to use scan lines above the nominal 486 line image area for meta data, closed caption, and/or vertical interval time code. This can be seen on overscan monitors; however, it may not be what you are seeing.
07-12-2021, 08:22 PM
It's just chroma inconsistency, I see that the OP from VH sister thread is using the wrong setting for the VCR and capture card, not good when you see letterboxing all around the frame.
07-12-2021, 09:42 PM
I have fixed the issue using WinTV. Thank you everyone for the help, I highly appreciate it.
| Thread |
Laserdisc capture: What is this line at the top?
bilbofett |
1 |
07-22-2019 09:16 PM |
Weird chroma flicker, how to remove from VHS capture?
koberulz |
13 |
12-05-2018 03:06 AM |
Weird vertical lines on VHS capture?
Specific |
5 |
09-03-2018 05:23 AM |
Line on Screen During Capture
JoRodd |
2 |
02-28-2018 07:47 AM |
Weird copy protection over my capture? (Star Wars!)
DeeSeven |
13 |
10-07-2015 11:10 AM |
