04-19-2022, 10:30 AM
Rookie20 Rookie20 is offline
Hello everyone,
I am looking for software to transfer a completed family movie dvd to a new dvd. I want to make multiple copies for family member's. Is there a recommended way to proceed with this transfer?
I do not mind paying for the software.
Looking forward to advice
Thank you
Glenn
04-19-2022, 12:11 PM
autephex autephex is offline
Are you asking about a good program to burn the DVDs or just copying them? A finished family movie DVD should not have any copy protection on it. You should simply be able to copy the VIDEO_TS folder to your hard drive and burn as many DVDs with that as you'd like. You'd create a folder called something like FamilyMovie, and then put the VIDEO_TS folder with its files into the FamilyMovie folder. Open your DVD burning program and select the FamilyMovie folder to burn a copy
The following users thank autephex for this useful post: Rookie20 (04-21-2022)
04-19-2022, 01:24 PM
TMPGEnc Authoring Works is a good software and easy to use imo. There are better but more complex aswell. If you know very little and expect decent to good quality that's the one.
The following users thank themaster1 for this useful post: Rookie20 (04-21-2022)
04-19-2022, 07:20 PM
There are many products that can be used to copy CDs, DVDs, and BDs. Many free/shareware as well as paid-for products. I normally use NERO for making copies and burning because it works for me, and I've been using it since the days it was bundled with CD burners. Like many produces that were take commercial, the NERO product line expanded and became became bloated with stuff I don't need, but the ROM burner still works for me.
Making copies of copy protected and region coded media is a separate issue and commercial products are required to respect that when used to make copies of media. There are products that can assist you in that process (e.g., REDFOX.BIZ's AnyDVD and others) but their use may be restricted in some jurisdictions.
The following users thank dpalomaki for this useful post: Rookie20 (04-21-2022)
04-21-2022, 08:47 AM
Thank you for Autephex, themaster 1 and dpalomaki for your help, I do not want to make copies of protected dvd's. I just want to make 1:1 copies of family dvd'd. When you google dvd copy software there is a lot of choices and I was looking for advice on what software was recommended
Glenn
04-21-2022, 09:25 AM
Good 'ol CDBurnerXP is as good as any if you just want to duplicate.
A very old, but well-loved bit of freeware, simply click 'disc copy' and follow the prompts. There's no need to overcomplicate this just to duplicate an extant DVD.
04-21-2022, 12:17 PM
Glenn
"DVD Copy software" would generally refer to programs designed to copy commercial dvds that are encoded with protection.
Just copying your personal DVDs is as simple as putting the disc in your drive, and copying the folder contents to your harddrive. Then burn that using any DVD burning software. I've always used IMGBurn personally, which is completely free, easy to use and very reliable
Found a copy of ATI USB 650 tvPortal software jwillis84 Capture, Record, Transfer 0 01-02-2020 07:48 PM
Tapes to capture/transfer, hardware/software to use, need guidance colony Capture, Record, Transfer 10 09-15-2018 01:50 PM
What hardware/software to copy Hi8 to DVD? allegheny Project Planning, Workflows 8 02-11-2015 09:40 PM
Software to allow recording of copy protected VHS tapes? Ali071 Capture, Record, Transfer 2 09-10-2012 09:54 AM
Burning Software to copy non-commercial DVDs? MagnificentMarcus Blank Media 13 06-26-2005 12:28 AM
