02-22-2023, 08:12 AM
MattTheGamer MattTheGamer is offline
I recently picked up a Samsung SV-5000W from a coworker and I noticed it has a SCART port on the back. I know a little about the port, namely that it is capable of outputting RGB, Composite, or S-Video but usually only one (from what I've read).
I plan to use this to digitize some of my parent's old home movies (everything is NTSC), so I'm not looking for pixel perfect capture I guess. My plan was to get a composite to HDMI adapter (or potentially run this through my Denon S760h receiver without the need for an adapter) and run that into an Elgato HD60S I have laying around and use something like OBS to capture the video output. I know it's probably not the preferred way of doing it, but I have this equipment already and (unless it's going to just be awful) I'm not too keen on investing hundreds of dollars into it. For now.
But with my question, given that SCART could output something more than composite, how can I tell what it is? If the SCART port outputs RGB or S-Video, I would want to use that instead of just normal Composite yeah? I would pickup a SCART to HDMI adapter (or buy/build an OSSC to handle it) in that case.
Thanks!
02-22-2023, 09:00 AM
On these (and most other VHS VCRs with SCART) it only outputs composite video + audio.
02-22-2023, 09:10 AM
Gotcha. I'll just get a good quality RCA composite cable and plug it into my AVR to start and see how it all looks.
02-22-2023, 09:30 AM
Should also note that a working one of these go for a fair bit of money since they can play all tape systems, so if you are not planning to keep it you will be able to recoup a fair bit of cost from selling it if you end up going for a fancier capture setup.
02-22-2023, 10:11 AM
That's what I've seen. We agreed on $100 since he just wants to get rid of it and have it be used; as it's been in a box, unused for a long while. We saw it was going for several hundred on eBay, but he offered it for $100.
02-22-2023, 11:48 PM
an Elgato
OBS to capture
(unless it's going to just be awful) !
This will look awful. Every color value, contrast, exposure, and even aspect, will be screwed. Not exaggerating here. Bad, crap quality, often wholly unviewable schlock.
You may not get another shot. Tapes are within that 35-65 year lifespan now, and many 80s tapes are degrading now. (In the 2000s, it was all BS to sell you stuff. But now, 20 years later, some truth to it finally. I see far too many degraded tapes now, flaking oxide.)
Too often, tapes are one-and-done. What you get is all you'll have. I hate it when I come across self-destructing tapes, especially homemade masters (ie, when lost, lost forever).
There is a middle ground between "cheap crap" and "high-end workflow". At least add the ES10/15, and a decent capture card. It's not what I would suggested, but even the cheap Live2 USB card is vastly better than the junk you're considering.
Buy it, use it, resell it.
- quality gear holds the best value
- but you can recoup a few bucks from the budget gear like this
- the HDMI/Elgato junk is yours forever.
02-23-2023, 06:32 AM
I'll go re-read through the stickied threads on capture cards and such then. But let me see if I understand the flow of this properly:
This Samsung VCR -> DMR-ES10/15 (or something to help clear/stabilize the image) -> something better than the HD60S I have (be it that Hauppauge cable or something else entirely) -> the output of that capture device into my computer
Is that right? Not VCR -> DMR and record to a DVD and rip the file off the DVD?
denon, elgato, samsung, sv-5000w
AG-1980 no video/audio output signal? FishonDavid Video Hardware Repair 3 07-13-2022 02:58 PM
VCR head output signal? ChrisTopia General Discussion 15 06-05-2020 06:49 PM
Samsung SV-5000W world vcr tape won't eject? waloshin Video Hardware Repair 1 09-30-2018 04:32 PM
Can JVC HM-DR10000EK output component video via SCART? david151 General Discussion 2 10-17-2016 08:28 AM
Do I lose PQ advantage switching signal from s-video to RCA in signal path ? Mejnour Project Planning, Workflows 4 02-01-2012 05:12 AM
