02-25-2023, 09:20 AM
Hi, I'm new around here. I will try to keep my question short and concise.
purpose: digitize old family videos on vhs
the videos are copies of originals i think vhs-c ("big old black camera" from the 90's) connecting the camera to the vcr and recording them.
I'm in Europe/PAL
first question:
My budget only allows me to buy a dazzle dcv100 or a Hauppauge usb-live2. Which of the 2 will give me the best result? or is it indifferent? the VcR will be a "normal" one without TBC.
I also have a choice of WinTV-HVR 1100 / 1110 / 1200 / NOVA-S-Plus (and others) pcie cards but I will use windows 10 and I don't know if they will give me compatibility problems (I assume that dcv100 and usb-live2 will work fine with windows10)
second question:
I have read that it is best to play the tapes with the same VCR with which they were recorded. Is this true? Right now the VCR I have isn't the same one the tapes were recorded with, but I might get it.
If the VCR is not super-VHS, (or the tapes) is it better using s-video or is it the same as using composite?
In my current VCR I don't have an s-video output, but I do have SCART. Is a scart to s-video adapter better than a scart to composite or is it the same?
thank you so much.
02-25-2023, 12:35 PM
I can answer the second question, Playing tapes on the same VCR that recorded them is not a general rule, Only if the VCR that recorded them was miss aligned. And yes playing normal VHS tapes in a S-VHS machine using S-Video socket or the Y-C pins on a SCART connector yields better quality than composite connector from the same S-VHS machine or a normal VHS machine.
02-27-2023, 08:51 AM
I would personally recommend AGAINST the Dazzle... I have heard that results are hit or miss depending on the hardware you received, and for me, it was definitely a miss. I didn't compare against the Hauppauge but others have reported that unit works better than the Dazzle. Here are my Dazzle test results: https://www.youtube.com/watch?v=bIjl2mLvaPk
02-28-2023, 07:42 AM
Sorry, I think I expressed myself poorly. I meant to ask if I would notice an improvement using an adapter to s-video with a regular VCR that has a SCART output. Is it the same as using a SCART to composite adapter?
02-28-2023, 08:03 AM
Double post sorry
02-28-2023, 08:05 AM
Double post, sorry
02-28-2023, 10:29 AM
If the VCR is not S-VHS that means it does not have S-Video out or C pin on the SCART connector therefore there is no benifit of converting composite (CVBS pin on SCART) to S-Video (Y-C) unless the convertor itself has a good comb filter to eliminate chroma artifacts, such as a DVD recorder, a TBC ...etc. Passive cable connectors will not add any benifit other than the convenience of connectivity.
| Thread |
Dazzle DVC100 higher quality than ATI AIW?
MatMK |
5 |
12-23-2022 04:54 PM |
ATI 600 vs. Tevion vs. Hauppauge USB-Live2?
mbassiouny |
6 |
06-16-2021 05:11 PM |
Dazzle DVD Recorder HD vs. Hauppauge USB-Live2?
Delta |
12 |
04-28-2021 07:44 PM |
Is Hauppauge USB-Live2 any good?
Lee B |
9 |
07-16-2020 05:45 PM |
New to video capture, but learning + Dazzle DVC100?
jimmyz80 |
Project Planning, Workflows |
19 |
08-19-2015 08:11 AM |
