02-28-2023, 01:05 AM
RelaxRelapse RelaxRelapse is offline
So I'm attempting to archive a few tapes, but my VHS player is having issues with its built in TBC. I've attached some examples below, and the built in TBC generally works as it should, but seemingly pushes the bad color data off to the right side. I don't actually know if that's what its doing, but that's what it feels like. The issue is more noticeable on pinks and greens, but is still present throughout. When the TBC is turned off, the color is fine throughout the entire picture.
I'm sure on a CRT it wouldn't be as noticeable, but for archiving purposes it is kind of distracting.
I do own another S-VHS player and an external TBC, but both need some touch ups or repair before I can test them.
Anyways, TL;DR: Is this a common issue, and can anything be done about it? If it's bad capacitors I could fix that easily, but if it's just how the chip works that's doing the correcting, then I'd rather not mess with it and just find an alternative (ex. other S-VHS VCR or fix/buy a working external TBC).
Thanks for any help!
02-28-2023, 02:14 AM
I would assume it's a problem, because it shouldn't do that, But troublshooting such a problem can be deficult, If you think it's worth it start from the power supply first, check all voltages and capacitors and then move to the video board.
02-28-2023, 01:50 PM
Thanks for the response! That's what I had figured unfortunately. I opened it up earlier and the TBC is actually a separate board, and easy to access. I might have to poke around and there and see if I can find anything off.
JVC PAL VCRs with built-in TBC? mrwassen Videography: Cameras, TVs and Players 1 05-11-2022 06:27 AM
Color issues in VHS video, editing issue after capture? billybatts Restore, Filter, Improve Quality 2 06-21-2021 07:33 AM
AG-1980s with recording issues (snow, tracking, color lines): worn heads? tapekeep Video Hardware Repair 7 03-17-2019 03:48 PM
Beginning to digitize tapes, issues with color? joh4 Capture, Record, Transfer 16 01-05-2019 01:54 PM
Color Corrector issues? wheezer210 Capture, Record, Transfer 1 05-31-2006 09:10 AM
