04-07-2023, 10:29 AM
packsnap85 packsnap85 is offline
I know this should be easy, but I am struggling to write a script that writes the frame number and YDifferenceFromPrevious to a log file if it is below 0.7. I have tried WriteFile, but it only seems to write the values for the current frame in the virtualdub window. Any help would be greatly appreciated.
04-08-2023, 06:15 AM
lollo2 lollo2 is offline
Have a look to this thread: https://forum.doom9.org/showthread.php?t=183582
Final version of the script here: https://forum.doom9.org/showthread.p...87#post1960487
It uses RT_WriteFile rather than WriteFile; it is field based, but you can easily change it for frame processing.
How to replace frames with duplicate frames? bmichaelb Restore, Filter, Improve Quality 9 09-09-2022 03:11 PM
Removing duplicate frames in digital file? thestarswitcher Restore, Filter, Improve Quality 0 07-12-2019 12:55 AM
Panasonic ES15 duplicate frames? Alert, problem! thestarswitcher Capture, Record, Transfer 2 07-02-2019 01:45 PM
Problem removing duplicate frames? doodal Restore, Filter, Improve Quality 17 12-28-2016 12:58 AM
Encoding is adding duplicate frames bbartley9 Encode, Convert for discs 6 09-01-2010 11:05 PM
