I bought this cheap unit, a PAL one, the image was soo distorted, cleaned the heads , cleaned rollers an any other things, replaced the belt.. but still no changes...
also the image not seems to going better after hours BUT also seems a little lit better when the unit is just powered.
internally was very clean (just old dust) , probably it worked not too much..
i was thinking this can be a capacitors issue, i removed 10 of them, checked the ESR and was all right... (2 ohms) ...
without playing a tape the MENU screen is PERFECTLY displayed without ony kind of noise.
the linear audio is good without noise.
any hint?
very thank you for the help!
