12-08-2023, 03:51 PM
JaiFai4K JaiFai4K is offline
Hi I started capturing my VHS tapes recently, all my setup is explained in this thread:
https://www.digitalfaq.com/forum/vid...panasonic.html
There is almost no issues on capturing commercial tapes but I am seeing this kind of wavy 'artefact' or noise like a continuous boomerang watermark alongside the tape and I don't know if this specific noise has a name or is a common problem,
can anybody help me?
I upload a small clip of the Domino Day 2005 recorded on TV, you can see it... What is causing this issue? Macrovision? Do I need to use any filter on AviSynth?
12-08-2023, 04:25 PM
interferences during the recording of the tv program is my best guess. Filters like Neatvideo or Defreq should help get rid of them
The following users thank themaster1 for this useful post: JaiFai4K (12-09-2023)
12-08-2023, 04:42 PM
Post a picture of what the output looks like without any in-line devices (so just VCR direct to capture card) and the TBC within the VCR turned on versus turned off. Seems the source. That just seems like a crazy amount of noise and if it's less or goes away when leaving out the ES10, that'll say whether it's that causing it or not
The following users thank aramkolt for this useful post: JaiFai4K (12-09-2023)
12-08-2023, 07:10 PM
timtape timtape is offline
Just listening to it, the audio sounds very distorted.
The following users thank timtape for this useful post: JaiFai4K (12-09-2023)
12-09-2023, 06:27 AM
This is only the SVHS (no ES10, no tape inserted) menu image vía s-video cable to capture card. I guess it must be distortion on the tape.
I played the tape in other 'crappy' VHS, tested other input (composite, SCART...) same interference in every setup...
File Type: avi svhs no tape via s-video still menu.avi (86.55 MB, 14 downloads)
12-09-2023, 03:35 PM
If it's got all kinds of distortion and rolling in the static menu, seems something is wrong with either the VCR or the capture card. Does it look like that when you hook it up to a regular TV monitor or CRT, or just when viewing through the capture card?
Audio noise from VHS Pomaze_Bog Edit Video, Audio 4 07-10-2023 07:23 AM
TBC-3000 noise? What's the cause? SinghDk Capture, Record, Transfer 29 11-20-2022 10:47 PM
Red and blue noise on VCR? xgamerd600 Video Hardware Repair 5 12-01-2020 10:03 PM
Diagonal line noise on VHS video? Luma noise? bilditup1 Capture, Record, Transfer 66 10-17-2015 01:03 AM
