02-21-2024, 07:50 PM
andrewprjnn1 andrewprjnn1 is offline
Not sure what is going on or if anyone has encountered this, but upon encoding my captures from .avi to .mp4 through Hybrid, the files are playing with inverted colors.
I've followed the recommended settings shared by lordsmurf through this thread https://www.digitalfaq.com/forum/vid...rocedures.html but I keep getting strange results. Tried digging around the forum as well for similar encounters, but no luck.
They are also not playable on PC in .mp4 through Windows Media Player, but are playable through Mac on Quicktime, only thing is the inversion for whatever reason.
Captured through VirtualDub and utilizing Hybrid 2021.01.31.1 downloaded and step-thru followed from digitalFAQ for reference.
Lordsmurf, Selur or anyone in the community, advice? Thanks everyone!
02-22-2024, 05:06 PM
Inverted colors may be a source codec issue. Lagarith, by chance?
02-28-2024, 02:01 AM
Attempted with lagarith and avc, but both giving same inverted results. Attached one of the encoding's mediainfo below for reference.
conversion, encode, hybrid, mp4
Strange results deinterlacing QTGMC in Hybrid? herlev Encode, Convert for streaming 2 04-13-2022 06:30 PM
Cut/Edit AVI files and then encode, or encode and then cut/edit? rks84093 Restore, Filter, Improve Quality 4 11-08-2018 01:55 PM
VHS capture - how to get best results from JVC HR-DVS3EU? AJAX1 Capture, Record, Transfer 9 04-04-2015 09:04 PM
Encode or re-encode, one progran as good as another? cyber-junkie Encode, Convert for discs 1 08-13-2010 05:05 PM
DVD Authoring - Poor Results ishmot Author, Make Menus, Slideshows, Burn 9 03-16-2005 12:08 PM
