05-13-2024, 11:35 AM
araset araset is offline
Hi I have question if for this card ATI AIW x600 pro
https://www.kleinanzeigen.de/s-anzei...13591-225-8348
will be good such breakout cable? Thanks for every answer.
https://imall.com/product/WIESON-1-P...4-197938804/en
05-13-2024, 12:50 PM
aramkolt aramkolt is offline
You're unlikely to find a breakout cable at a reasonable price, most of them got tossed years ago when people forgot about or stopped using what they went to. Good news with that one is that at least the cable isn't needed to use it as an actual graphics card. If I was you,
I'd consider wiring up composite and S-Video to the small AV in header on the board itself as described here using a JST PH 2.0mm 8 position male pin socket as described by Jwillis84: https://www.digitalfaq.com/forum/vid...onder-pci.html
...Or you could just remove that header and solder a composite cable and S-Video cable to where the header was with the appropriate pins. Both will require some basic soldering though. This option is probably technically the easiest assuming you have a decent desoldering gun or have fine soldering skills to solder directly to the existing pins.
05-13-2024, 03:27 PM
Is this the All in wonder version of 9600 pro? Thanks.
https://www.olx.pl/d/oferta/karta-gr...&sliderIndex=2
05-13-2024, 09:35 PM
x600 is not 9600.
For which card? Again, don't mix up AIW models.
05-14-2024, 07:48 AM
This card has everything which is needed?
https://www.kleinanzeigen.de/s-anzei...50786-225-3822
I can connect this card with modern tv with composite (yellow), jack with computer sound card and s video with svhs player?
05-14-2024, 08:23 AM
Yep, seems so, good deal.
[SOLD] For sale: ATI AIW VE PCI (AGP) + breakout cable metaleonid Marketplace 0 04-24-2023 08:19 PM
ATI All-In-Wonder 9000 Pro breakout cable? geordie10 Project Planning, Workflows 1 01-08-2023 06:35 AM
Is regular s-video cable as good as Monster cable? ThumperStrauss Capture, Record, Transfer 6 01-03-2022 05:31 AM
Looking for S-video breakout cable (to RCA) eonmc2 Marketplace 1 09-29-2013 03:12 PM
How to split cable TV and cable internet coax for two rooms ? stoogedog Computers 6 12-05-2006 06:15 AM
