03-23-2025, 08:19 PM
hothbase hothbase is offline
NV-HS950 connected to GV-USB2 via S-Video.
Not sure if ghosting is the correct term. There's an outline slightly shifted to the right. It's most evident with text, such as subtitles. Also clearly visible in the VCR's configuration menu, so I don't think it's my tapes.
Any idea what's causing this? Could it just be the VCR?
Thanks.
03-24-2025, 11:47 AM
aramkolt aramkolt is offline
Halos are probably the more-used term, but generally it can be seen with oversharpening. You could probably change some settings, but the rest of the picture will then appear less sharp.
See this post below about your machine specifically:
https://www.digitalfaq.com/forum/vid...-nv-hs950.html
03-24-2025, 02:08 PM
Thanks for the reply. I considered halos, but don't those normally appear around the entire object? These ghost images always appear to the right.
Very apparent on the "T" and "i".
Easiest to spot on "4" and "3" here.
This deck doesn't really offer much in terms of configuration. I've tried switching Edit Mode off and toggling 3D DNR - to me they don't really seem to affect the picture at all, in any scene. Maybe that's just my unit though?
Panasonic NV-HS950 image too sharp? benzio Capture, Record, Transfer 4 01-07-2026 10:26 AM
Panasonic NV-HS950, cassette locked inside? promoter_2000 Video Hardware Repair 13 12-05-2021 08:42 AM
Panasonic NV-HS950 vs. NV-HS860? Uraz88 Capture, Record, Transfer 0 05-14-2021 05:33 AM
Panasonic NV HS950: no playback, in/out signal? promoter_2000 Video Hardware Repair 2 06-23-2020 10:09 AM
Panasonic NV-HS950 digital artifacting on some tapes? herregaarden Video Hardware Repair 6 05-01-2020 01:16 PM
