08-24-2025, 01:30 AM
radiokom radiokom is offline
I got Matrox RT.X100 Xtreme Pro together with input module (will receive after a week) for EUR 50.
If I understand correctly, problem with those is the same as with Lynx One sound cards - good cards, but works only under XP. It is not a big problem because I have serviced XP machines where it can be used.
Opinions about that?
08-24-2025, 01:54 AM
25 years ago, yes.
Now, no.
RT.X cards rely on not just XP, but outdated software like Premiere 5/6.
I used to really want this card. Now I wouldn't use it if it were free.
08-24-2025, 02:26 AM
Ok, thanks! EUR 50 is not a big mess
I have (licensed) Adobe Premiere Pro 2.0 in my archive folder. But well, to mess with it would be likely masturbation (pardon the expression). I just sometimes buy useless toys (but cheaply)
But I believe this should be updated:
https://www.digitalfaq.com/guides/vi...rd-capture.htm
However just curious - if it support capture of lossless YUY2 (I am not sure, really did not investigated this ) in Premiere Pro 2.0, why it could not be used for capture?
Later captured file can be edited in another programs.
08-24-2025, 03:25 AM
All of the guides need 2020s updates.
Matrox cards pre-date Premiere Pro by about a decade. I don't refer to Premiere Pro 5/6, but pre-Pro 5/6. Ancient versions. If IIRC, RT.X is DV and MPEG only, not lossless.
Save that €50 for literally anything else, even non-video (a steak dinner, whatever).
08-24-2025, 03:31 AM
OK, will do!
Matrox RT.X2-board and Windows 10 or 11? mergebow General Discussion 0 01-10-2023 01:13 AM
Matrox MX02 for capture? See D0S run Capture, Record, Transfer 15 08-15-2022 09:05 PM
Why is ATI preferred over Matrox MX02? mr-jolly Capture, Record, Transfer 12 05-18-2020 03:24 PM
Matrox MXO2 LE Max vs. ATI AIW with VHS? jjdd Capture, Record, Transfer 20 02-09-2020 06:38 AM
Matrox MX02 Mini MAX waloshin Capture, Record, Transfer 0 05-08-2017 08:36 PM
