12-03-2009, 10:28 AM
ieee488 ieee488 is offline
I have a DVD-RW that I recorded which will not finalize. error E19.
Is it because I recorded too much on it?
Unlike my JVC, the Magnavox does not give me a good feel of how much is left on the disc based on the recording mode SP that I have set.
12-03-2009, 10:42 AM
jthomas jthomas is offline
Hi, I have a 2160 also. not sure of your problem, but I don't usually finalize DVD-RW. Actually it doesn't even allow that for me. Actually I'm using DVD+RW.
12-03-2009, 11:20 AM
Was this disc full to the edge? Errors like this usually happen because the disc is bad -- it fails out on the outer edges, past about 3.8GB of data.
12-03-2009, 01:43 PM
The disc is a Fuji made in Singapore that I have used multiple times before usually I record full 2 hours to it. However, this is the first time I have used it with the Magnavox.
Perhaps I should do a full format?
I am not quite sure how to do that. I usually choose Erase Disc.
I am thinking that the Magnavox doesn't quite like DVD-RWs. The problem is that I have at least 30 of them. Hate to throw them away.
12-03-2009, 10:03 PM
Yeah, a full format may help -- maybe. Can't hurt. Put the disc in your computer, open up the freeware tool ImgBurn, and then go to
  • Tools >
    • Drive >
      • Erase Disc >
        • Full
And then erase the disc with a full format. It should complete in about 15 minutes. That will refresh a DVD-RW/DVD+RW, restoring it to a virgin state.
If it fails during format, it's definitely a bad disc.
ImgBurn is available at http://www.dvd-recordable.net/Downlo...-lid-119.phtml
12-04-2009, 08:47 AM
Thanks for the tip about ImgBurn. I have that program but did not know that I can format using it.
I was also glad that I had Isobuster and was able to rip the video to my computer hard drive even though the disc would not finalize.
Panasonic can finalize JVC discs lordsmurf Capture, Record, Transfer 13 07-26-2013 02:52 PM
Magnavox H2160MW9 any good? lordsmurf Capture, Record, Transfer 12 04-02-2010 01:23 AM
Magnavox H2160MW9 finalized disc not recognized ... ieee488 Capture, Record, Transfer 8 11-13-2009 03:46 PM
Magnavox H2160MW9 -VR mode only ?!?! ieee488 Capture, Record, Transfer 10 11-01-2009 07:01 PM
