09-18-2013, 12:39 PM
DeeSeven DeeSeven is offline
I've been messing around with my "new" ag-1980 and somethings I can't quite figure out...
1. The linear audio option. Isn't linear audio just uncompressed audio? where as the L+R cables are lossy? if that is the case how does one capture the linear audio if they use a ATI 800 USB?
2. If I capture in Svideo how do i capture the audio at the same time as svideo only carries video not audio? I can only select either or on the vcr and virtualdub.
09-18-2013, 05:26 PM
tomswift tomswift is offline
On S-VHS/VHS linear audio is the audio recorded along the edge of the tape (also we are talking about an analog video format here not a digital one). It is the same track that VCR's use for mono recordings, or linear stereo (where it splits the track in 2). This is not Hi-Fi stereo, so the audio quality will not be as good as a Hi-Fi recording. I don't use the ATI 800 since I find it doesn't give the best quality, but you'll be able to get linear audio over the regular audio out (I think the AG-1980 uses the regular red/white RCA connectors).
When you hook up your S-Video and the RCA red/white cables your capture card will capture both at the same time. It would just be as if you were using the yellow RCA with the red/white cables.
09-18-2013, 07:39 PM
yeah dont bother with the linear - use the red and white stereo audio.
do you mean ATI600USB? never heard of the 800USB
the 600 is a decent device, just dont use the default settings
there has been a guide in the works for some time for the 600
hopefully it will be released soon
09-19-2013, 01:14 PM
and yes 600 lol sorry
thank for the info. Ill keep my eyes peeled for that guide thanks volksjager
09-26-2013, 11:48 PM
Threadjack about the ATI 600 USB capture card vs. Canopus ADVC-300/55/100/110 capture card has been moved to its own topic.
See the thread at http://www.digitalfaq.com/forum/vide...i-600-usb.html
Thanks!
This question has been split from another post or thread. This was done in order to address the topic more in depth, make it easier to find via forum searches, as well as prevent the other post/thread from going too far off-topic. Please continue this part of the conversation here. Thanks for understanding our tech Q&A policies.
Panasonic AG-W1 only plays linear audio after head cleaning? sawing14s Video Hardware Repair 1 12-14-2023 01:44 AM
Panasonic VCR bad linear audio? pthebest19 Video Hardware Repair 19 08-22-2023 07:43 AM
Panasonic AG-1980 audio low? crissrudd4554 Capture, Record, Transfer 17 11-06-2021 07:03 PM
AG-1980 suddenly only plays HiFi tapes in linear mono? FF3D Video Hardware Repair 4 07-30-2021 08:24 PM
Panasonic 850 linear audio: hiss and dropouts, cause? Koen Video Hardware Repair 23 04-07-2021 11:20 PM
