03-12-2014, 11:09 AM
dansms dansms is offline
I guess these have to be bought from the US. How would I plug this into UK wall socket? Would it be just a case of buying a travel adapter or is there a need to convert to US power ratings?
03-12-2014, 11:32 AM
you dont plug a capture card into the wall - they are powered by the computer
03-12-2014, 11:41 AM
Oh, ok, am I looking at the wrong item:
http://www.ebay.co.uk/itm/ATI-TV-Won...item416e4b6db7
It says it's missing an AC adapter. Is there a different type of ATI 650 USB?
03-12-2014, 11:46 AM
I believe this one does require an AC, you may be better off going with a USB solution. It really comes down to what you are capturing. I have used a Pinnacle 801e for VHS capture with Virtualdub with good results.
As long as you are capturing SD, no problems with going with USB 2.0 or higher.
03-12-2014, 12:00 PM
hmm- never seen on of those....
look for an ATI600USB - the 600 chipset is better than the 650 and is powered by the USB port
03-12-2014, 12:07 PM
Yeah, I was going for s-video to usb and from reading these forums it was recommended to go for the ATI 600 USB or ATI 650 USB. The ATI 650 USB seems more prevalent. Couldn't see the Pinnacle 801e at all (on ebay)
03-12-2014, 01:05 PM
Mine has S-Video, 3.5mm headphone jack in, and RCA video in. I haven't used the ATI so I can't compare them but I'll sell you mine for cheap if you want it.
http://www.bhphotovideo.com/bnh/cont...=REG&A=details
Not sure if BH will ship to the UK but they are very good.
600 usb, ati tv wonder 650, power
AV to Component adapter? bigk181 Videography: Cameras, TVs and Players 3 12-24-2012 01:13 PM
Elite Video BVP4+ UK Power adapter powellfan Video Hardware Repair 3 06-09-2012 09:35 AM
JVC HR-S7955EK power adapter for 110V Mejnour Capture, Record, Transfer 1 02-20-2012 11:20 PM
VHS-C Camcorder vs. adapter playback NJRoadfan Restore, Filter, Improve Quality 9 01-26-2011 08:20 AM
Atari 2600 adapter!!! MOTUfan Videography: Cameras, TVs and Players 3 09-26-2005 07:11 AM
