01-28-2019, 09:41 AM
kriscraigs kriscraigs is offline
Hi everyone, thanks to the help on this forum I'm really moving along in my video transfer project tests! I probably have ~50 8mm tapes (mostly video8) and I'm eager to find the "perfect" setup so I can start to memorialize them digitally. Am testing HuffYUV, Lagarith, and now MagicYUV to see which works best. I've read that super helpful settings guide as well.
SETUP:
I've got an Osprey 100e PCEI card using svideo that seems to be working great, with output from a Sony GV-D800. I'm using a Windows 10 64-bit PC. I want to optimize these videos for TV viewing.
CHALLENGES
1. No matter what I try, the videos all tend to have a few horizontal lines at the bottom of the screen but I understand these may be expected. Is this fixable?
2. Should I be using 640x480, or 720x480? And if 720, it's not an option for me in CapturePIN. And when I try to change it in Set Custom Video Format, VirtualDub gives me this error "The capture device does not support the selected video format." But, the Osprey 100e specs clearly show it DOES support 720x480 capture. And, should I worry about this - or just capture at 640?
THANK YOU SO MUCH!
Kris
01-28-2019, 04:10 PM
You may have "square pixel" turned on in your driver settings. This limits the horizontal format.
Try "CCIR-601" and see if you can select 720x480
01-28-2019, 04:26 PM
VirtualDub > capture AVI > set custom format > 720x480
VirtualDub is unable to see my ATI 600 USB capture card? stevevid Capture, Record, Transfer 8 09-12-2018 01:03 PM
DTS audio file, unable to hear after authoring? manthing Encode, Convert for discs 3 02-12-2018 05:09 AM
Unable to enable Shell Fork Bomb Protection in cPanel ? kpmedia Web Hosting 0 01-27-2012 12:40 PM
"Unable To Start TV" , ATI X800 series Card JLegnon Capture, Record, Transfer 3 10-03-2011 06:25 PM
Unable to get Flash vid to display in transparemt mode vidweb Encode, Convert for streaming 5 03-04-2011 04:56 PM
