06-13-2021, 06:19 PM
What brake pads have to do with playback?
FWIW: Can't speak to this mechanism specifically, but with many tape transports the brake band is used to apply a slight amount of drag on the supply reel to ensure proper tape tension on the supply side of the capstan.
06-13-2021, 10:07 PM
If you mean the supply reel in a form of a band then yes, It would be an awkward engineering to use brakes to adjust tension on the take up reel, The take up spindle has already a felt pad built into it or the idler gear to adjust that tension, Even the OP referred to a youtube video in his first post about that.
06-14-2021, 05:16 AM
apfelmus apfelmus is offline
Originally Posted by apfelmus View Post
...Fortunately I have a 3rd G-chassis, from a bargain-W1 who's front panel was damaged beyond repair. The brake pads of this chassis seem clean, no debris. I'll swap them, and will report back...
Thats what I did the other days. Attached some pics of both pads. Its felt, but with some black coating on top that gets off quite easily. I first thought it was dirt... These brake pads are not even shown in the exploded views in the service manual! No part number. Strange, they seem to be a maintenance item as they clearly wear out.
Result of the swap was a decently working VCR, but I'm not sure whether that is due to the brakes or if there was something else. I now notice that the pads do indeed not touch the takeup reel in play-mode. Couple seems quite OK. I do not have a torque gauge, but when I hold it with my fingers it feels reasonable. Is there a quick-and-dirty method to check whether torque is in the required range?
The other VCR, the one that seemed to smoke a joint, is working happily since. I still have no idea about what could have caused it. Eventually one of the zillions of electrolytics went bad somewhere in a circuit I do not use when playing Secam to PAL...? Power rails are all good, so if it was an electrolytic it either went open circuit or it shorted out and charred a series resistor or a part of the printed circuit.
Does anybody know if there is a way to access the parts that are hidden by the RCA sockets on the output board? I couldn't figure out a way to remove the plate holding the sockets from the board except by desoldering all of them. Most of the remaining smell came from underneath that plate, but I couldn't see anything wrong looking between the boards from the sides.
cheers
Martin
06-15-2021, 09:14 PM
Dougmc Dougmc is offline
Years back sony also maybe under zenith name
Had a pulley maybe 2" diameter with a string.
I assume used a tension meter,gram guage.
I couldn't find it on the web but there are sites discription
How to measure torque with a pulley and string.
Start with a hub out of a video cassette.
Add a pulley ..diy.project...
Maybe someone in the group is near u and would check
It 4 u....
06-15-2021, 11:21 PM
Sure, if someone near or in Stuttgart / Germany wants to drop by, he's welcome!
I thought there might be some ways like how electricians measured voltage by putting their fingers on the wire... :-) Experienced VCR servicemen sure could judge the right couple with their own fingers.
cheers
Martin
Panasonic FS200 squealing problem? lojelo5 Video Hardware Repair 7 03-29-2021 03:43 PM
Panasonic AG-7750 problem, no power up? josje22 Video Hardware Repair 10 02-08-2018 03:17 PM
Panasonic AG-8700 S-VHS VCR: a problem with TBC frankzaatar Restore, Filter, Improve Quality 2 09-05-2017 03:26 AM
Panasonic NV-HD620 LP/EP playback problem? nesburf Video Hardware Repair 10 03-07-2017 09:11 PM
Problem with Panasonic AG-1980 VCR Superstar Capture, Record, Transfer 2 10-20-2011 01:53 AM
