08-10-2022, 12:35 PM
FishonDavid FishonDavid is offline
im working on the Y/C board, yep, the 21 SMDs and the 12 pin hole capacitors, ive cleaned off all the old caps,
didnt even bother to check them, just removed, to replace, now im looking at my stock on hand of
pin hole caps vs SMD style, and find that im short several of the 47 / 6V of the SMD style, but have an abundance of the pinhole type, i want to know, is there any difference? can i use the pin hole version, in replacement for the SMD, with exact spec's of course, same uf/v of each? it would sure make my work alot easier, let me know if anyone has done this, and how did it work out for you?
thanks your anyones input on this subject
Fish
08-10-2022, 02:24 PM
As long as they don't interfere with other boards and the components adjacent to them as well as they don't obstruct air flow to other components surrounding them I don't see why not.
The following users thank latreche34 for this useful post: FishonDavid (08-10-2022)
08-11-2022, 06:12 AM
Probably, but check the sp0ecs (e.g., temperature, ESR, etc.) as well as physical size to be sure your proposed replacements are similar. or better rated, otherwise you might not get the expected performance.. Might be worth taking a few minutes to measuring your replacements before you install just to be sure they are good, especially if they are old bench stock..
I have replaced SMD with radial lead caps on other gear such as a wireless mic system with success.
The following users thank dpalomaki for this useful post: FishonDavid (08-11-2022)
08-11-2022, 08:30 AM
It appears to have worked out fine substituting the pin hole style onto the surface mount pads, i am glad i made the substitute, those SMD type are just too small of contact tabs for my liking, very hard to solder onto the pad, im sure the SMD's have a longer life span, (though those are the ones that were bad!!) go figure....
thanks for the input guys!!
Fish
11-26-2022, 08:14 PM
MrPete MrPete is offline
WOW! That's quite the improvement
This is a great example of the impact of new caps -- in this case on the Y/C board.
AIW HD Daughter Board ? CapsuleJ Capture, Record, Transfer 0 10-20-2018 01:05 AM
New capture board with pro TBC? (Blackmagic) josje22 Capture, Record, Transfer 8 04-28-2018 08:05 AM
Recapping the TBC board in JVC S9500U? x77x Capture, Record, Transfer 0 07-23-2017 06:07 AM
AIW 7500 AGP dislodged board component, can it be repaired? sanlyn Video Hardware Repair 9 09-16-2016 07:00 AM
Sound board recommendation w3tno Encode, Convert for discs 1 02-06-2005 03:02 PM
