01-03-2023, 12:25 PM
copyme copyme is offline
Hello,
Have anyone taken apart a vhs-c adapter (vw-tca7e) to clean/grease it?
I've got an original adapter that I guess came with an old video recorder. I've changed the battery but the motor seems very slow to stretch the band all the way.
So I guess it needs a bit care. But does it matter or will I just risk breaking it?
02-11-2023, 01:49 PM
Once motors start to seize and slow down, they're done. Motors are a common fail point with Matsuhita (JVC/Panasonic), of which this is surely one.
The frustrating aspect here is that motors can be fine one day, and then in a failing state next time you go to use it. These rarely degrade gracefully, but sudden. As the motor weakens inside, it pushes itself to maintain. Then one day, it can't maintain.
If you're cat owner, it's somewhat the same. Cats hide illness until it's too late. So preventative care is so important.
Sony EDV-7500 Beta service/refurbish/repair in 2019? captainvic Video Hardware Repair 8 01-22-2020 11:16 AM
Panasonic AG-7350 or Panasonic NV-FS200 for digitizing tapes? simo1427 Capture, Record, Transfer 3 05-21-2018 04:19 PM
Repair, refurbish 1640 BenQ DVD burner? WidowMaker Blank Media 3 12-13-2017 10:01 AM
Panasonic AG-5700E vs Panasonic NV-HS1000 for transferring tapes? tsakodim Capture, Record, Transfer 8 12-31-2014 10:00 AM
Can my Panasonic DMR-ES10EB record Freeview channels from my Panasonic TX-L-32G20B TV Peter_T_Ross Videography: Cameras, TVs and Players 4 09-01-2010 05:20 AM
