02-20-2023, 08:05 AM
Akuma786 Akuma786 is offline
The issue I'm experiencing is when I insert a SVHS tape, the VCR Initially picks up that it is a SVHS tape and the logo appears on front display of VCR but when i press the play button the SVHS Logo vanishes from VCR front display and the tapes all seem to have tracking issues continuesly along with the counter numbers not moving whilst on PLAY mode.
However when I press the FF button, the SVHS logo appears on the front display of the VCR and the picture looks clear whilst on FF and only then the counter numbers move compared to when on Play mode the counter doesn't move and tracking problems constantly.
I tried a few tapes and can't seem to get any working properly.
I have recorded the issue on my phone as i thought if you guys could see it you'll have a better idea of what I described.
I think the Head of the VCR needs cleaning but I could be wrong, but I rather ask you guys first for advice and tips on what to do.
Akuma786
02-20-2023, 12:20 PM
That looks like pulse signal problem, There is a stationary head that picks up linear audio and tracking pulses, Clean that head and make sure the tape passes through it in stable fashion, If it's curling or going up and down stop using important tapes on it (you can post a video of the tape path if you would like), Also check the same head ribbon cable and make sure its clean and fully seated on the head side and the main PCB side.
The following users thank latreche34 for this useful post: Akuma786 (02-20-2023)
02-20-2023, 12:52 PM
Thanks for replying. I'll take a look at that tonight and let you know. Much appreciated.
02-20-2023, 07:14 PM
So I have opened the top cover of the VCR and and posted video below. Is that white dust mould?
02-21-2023, 12:09 AM
timtape timtape is offline
Often mould can be seen by looking through the cassette's window where it appears on the top edge of the tape pack. Below is an example photo.
If it is mould, the affected tapes need to be identified and properly treated before being played. The deck also needs its mould affected internals properly treated. Mould can be a health hazard. I suggest you dont proceed without expert help.
The following users thank timtape for this useful post: Akuma786 (02-21-2023)
02-21-2023, 02:44 AM
Yeah, It is as dirty as a whore working double shift, You need to clean it thoroughly without being exposed to whatever that substance is.
The following users thank latreche34 for this useful post: Akuma786 (02-21-2023)
Decent S-VHS with DNR, auto-tracking, s-video? Darkmatter Capture, Record, Transfer 28 11-01-2021 05:37 AM
Tracking problems with the AG-1980 Panasonic VCR? RetroTy Video Hardware Repair 3 10-26-2012 05:50 AM
VCR tracking problems or grounding issue? Zerowalker Capture, Record, Transfer 9 08-06-2012 04:46 PM
VHS maintenance/cleaning - What problems do dirty heads cause? cyber-junkie Video Hardware Repair 5 02-12-2010 04:31 PM
