08-23-2023, 08:40 AM
RobertP RobertP is offline
I hooked up the 2011 Magnavox VCR/DVD and POOF! Had been working not 2 months before.
Powers on...then immediately off.
Smells like burnt electrical components.
I pulled it all apart and it looks like a transistor burnt/smoked.
Its the DVD side, looks like.
Car battery died that day too.
I know its not the greatest VCR/DVD of all time but it did work OK. I don't use it a ton.
I can solder and pull things apart and usually follow directions.
So what transistor would I need to repair this? Thoughts?
08-23-2023, 08:55 AM
hulkk hulkk is offline
You’d have to have a repair manual with schematic to know the value of the resistor. Maganovox customer service may be able to help. That may or may not fix the problem. For instance – what caused the resistor to burn out?
By the way – what is it about this unit that justifies the high selling prices on ebay?
08-23-2023, 10:27 AM
Magnavox customer service is not going to help him about a VCR, Thy moved away from VHS almost two decades ago, Their current technicians probably don't even know what VHS means.
Is there any advantage to using a DVDR in line with TBC? zippydan Capture, Record, Transfer 3 11-02-2021 12:27 PM
Magnavox ZV427MG9 jerrybarnesbass Capture, Record, Transfer 1 06-29-2020 12:15 PM
Repair source for JVC SR-W5U needed FrostBite Video Hardware Repair 4 11-06-2019 10:09 AM
Magnavox ZV427MG9 worthy DVD recorder? BarryTheCrab Capture, Record, Transfer 4 09-22-2017 12:41 PM
Magnavox DVD player to a Magnavox recorder, won't work lordsmurf Capture, Record, Transfer 0 08-20-2011 09:39 PM
