04-08-2025, 09:48 AM
enigmatic enigmatic is offline
Hi,
my JVC VCR turned on for three seconds and then turned off again. I found some tips in this forum and finally found the problem. The drum has a motorized angle adjustment. However, two adjustment screws are broken (see pictures) and some other broken components. (Maybe the first 3 pictures are correct and not broken?)
Does anyone have any idea how to fix this? Is it necessary to remove the video-drum (I think this would require a special tool), and assuming the screws can be repaired, can it be adjusted again?
The area isn't shown in my service manual.
Thank you for your help.
04-08-2025, 10:58 AM
https://forum.videohelp.com/threads/...m-Ultimate-Fix
The following users thank latreche34 for this useful post: enigmatic (04-08-2025), lordsmurf (04-08-2025)
04-08-2025, 11:07 AM
The drum was easy to disassemble
I'm not sure if superglue would help here.
04-08-2025, 02:32 PM
thanks a lot to latreche34. Thread can be closed.
The following users thank enigmatic for this useful post: lordsmurf (04-08-2025)
How to adjust VCR rewind speed? TOM1 Video Hardware Repair 14 10-03-2023 01:32 AM
New Drum or Drum Overhaul for Panasonic NV-HS1000 cafecafe Video Hardware Repair 4 05-20-2022 07:12 AM
Adjust JVC VCR with Jig RCU PTU94023B remote? Bogilein Video Hardware Repair 2 08-07-2021 11:04 PM
Horizontal adjust? mikeG Capture, Record, Transfer 5 07-02-2019 02:44 PM
Good wide angle lens for Nikon D7000 for under $200.00 ? Sossity Photo Cameras: Buying & Shooting 7 11-23-2010 02:09 AM
