06-05-2025, 06:48 PM
hothbase hothbase is offline
This HR-S8600EU sometimes (not always!) makes a rather concerning noise when transitioning in/out of (slow) rewind mode.
To clarify, it makes the noise when starting and stopping slow rewind, but also when it switches from slow rewind to fast rewind. Stopping the a fast rewind does not produce the noise.
Video of start & stop:
I don't think it's related to this but I'll mention it anyway: the unit has had DD gears removed, as described in https://www.digitalfaq.com/forum/vcr...amic-drum.html
06-05-2025, 09:33 PM
it make more noise when DD gears are removed. I did it on a deck aswell so i know.
06-06-2025, 05:29 AM
That's good to know, thank you. Did it sound as bad as mine?
I'm surprised that the noise could be DD related because I didn't think it would be engaged in normal rewind, only reverse search/play.
I'll open the VCR and attempt to pinpoint the source of the noise when I find some time.
noise, rewind, vcr
Automatically stop VirtualDub and VCR? cwig Capture, Record, Transfer 6 08-18-2023 04:37 AM
Aja Kona LHi: any way to stop capture after duration? waloshin Capture, Record, Transfer 3 01-14-2021 12:50 AM
Camcorder stop recognizing tape? HOAsRwrong Video Hardware Repair 2 09-04-2018 08:45 AM
Diagonal line noise on VHS video? Luma noise? bilditup1 Capture, Record, Transfer 66 10-17-2015 01:03 AM
