06-20-2025, 10:05 PM
GJP61 GJP61 is offline
I recently bought a Magnavox MDR867H/F7 and the remote that came with it will not work because it is set to RC3. So I bought a new replacement remote and it worked out of the box showing me RC1. However, all of a sudden it is showing RC3 now instead of RC1 like it did to begin with and it won't work with said DVD player/recorder. I've tried all the recommendations in the manual but nothing will return the remote to RC1. thank you.
06-27-2025, 04:50 AM
timtape timtape is offline
I have no specific knowledge of your remote or VCR but perhaps when the batteries become discharged or removed, the unit automatically defaults to RC3. I would check the remote's battery terminals are clean for good battery connection, then insert fresh batteries. Then I'd reset to RC1 as per the manual and see what happens.
Hope this helps.
Windows Media Player seek bar doesn't work? connierebel General Discussion 1 01-11-2022 11:25 AM
Which remote for Vestel DVD2216 player? maris68 Videography: Cameras, TVs and Players 0 04-08-2021 10:22 AM
Will a regular remote work for JVC S-VHS deck? dave_van_damn Videography: Cameras, TVs and Players 7 03-20-2019 12:15 AM
Will AG-1980 VCR TBC work for Betamax player input? deckhanddavy Capture, Record, Transfer 10 04-27-2014 05:53 PM
Do you need the remote to correctly work the Panasonic AG-1980 cyber-junkie Project Planning, Workflows 9 02-19-2010 11:46 AM
