Hi all
My JVC HR S7500 has started to act up.
It plays fine (recently popped in a new loading belt. The unit is DD otherwise with cams for FFS and rwd.
However, after pressing eject, the machine will eject the tape then immediately take it back in again in a continual loop
If I remove the tape the machine still tries to load and of course jams as the tape tabs are not moved out of the way.
I have attached a link to a video to show this.
https://drive.google.com/drive/folde...fA1BdMZilBf-ld
Any ideas? There does not seem to be a loading sensor but the machine does have a
Rotary Encoder. Maybe that's faulty?
Many thanks
