01-23-2026, 08:29 PM
jham55 jham55 is offline
I have not come across this problem before but the umatic loads and plays fine and the meters are picking up the signal. There is no audio or video though. So far I have tried the following
1. changed the drum assembly
2. cleaned the heads
3. The deck was already really clean but I cleaned the inside really well
4. Changed tapes
same issues.. nothing seems to get video or audio.
Sony VO-7600 tension issue? jham55 Video Hardware Repair 3 08-14-2024 07:37 AM
Umatic BVU-950P Chroma playback issue - just bad alignment? max_vid Video Hardware Repair 2 12-19-2018 07:19 AM
Audio issue/noise while capturing video from VHS? mosolygosgyilkos Capture, Record, Transfer 3 11-22-2018 02:39 PM
Converting VHS: audio/video sync issue! myparentscloset Capture, Record, Transfer 0 12-13-2016 09:14 PM
VirtualDub Audio/Video Sync Still An Issue? JasonCA Capture, Record, Transfer 1 01-31-2013 01:05 AM
