10-16-2016, 04:56 AM
willow5 willow5 is offline
I have heeded advice from this lovely forum and bought a 2nd hand panasonic NV-FS200 with built in tbc but alas it is not without a problem. The fault is streaks are appearing on screen which seem to mostly disappear when the machine is up to operating temperature so it appears to be temperature related. It is like the picture "shivers" when cold. A friend of mine has indicated that it could be an issue with the in-built tbc but I am not sure where to look. Could someone on the great forum help me isolate the fault? I have uploaded a picture of the problem. Thanks
10-28-2016, 04:22 AM
Quasipal Quasipal is offline
Hi, are you sure that this is not mechanical in origin like a failed pinch roller bearing, too high back tension or sticky lower drum? Always check the mechanics are 100% before moving to the electronics.
10-29-2016, 05:56 AM
That player outputs images at 890x501?
Panasonic FS200 faulty TBC? Maxx99 Video Hardware Repair 4 01-17-2017 02:07 PM
Benefits of using TBC on Panasonic NV-FS200? Maris 55 Capture, Record, Transfer 17 10-04-2016 09:40 AM
Panasonic NV-FS200 not working vaccastracca Video Hardware Repair 5 12-02-2014 08:30 PM
Which S-VHS VCR suggested? Panasonic HS 1000 vs NV-FS200 sangia Capture, Record, Transfer 1 11-12-2011 12:54 PM
Panasonic NV-FS200 playback problem zeroprobe Video Hardware Repair 13 12-01-2010 11:07 AM
