10-19-2019, 05:41 AM
RockCassette RockCassette is offline
Hello,
I would like to record videos from my desktop to get some program tutorials. Windows or Linux as operating system.
Audio may not be a big problem, as I'll add it afterwards.
With older PCs I use to capture from s-video or composite as their graphic card own. Now the older PCs are too slow for some apps and I need to use modern PCs that have not s-video or composite.
How can I capture my desktop?
Regards,
R.
10-19-2019, 11:23 AM
Why not use screen recording software?
If you do decide you need a capture device, recommendations would depend on whether you want the ability to capture lossless (device outputs uncompressed, allowing software compression) or not (device outputs hardware-compressed).
10-19-2019, 01:07 PM
VLC can do that
Capture with AVR+HDMI vs. analog capture device? bgalakazam Capture, Record, Transfer 3 10-31-2019 04:39 PM
Sony RDR-AT200 DVD recorder as TBC, capture via HDMI? jnielsen Capture, Record, Transfer 11 03-04-2019 06:31 PM
Capture hardware for HDMI, computer tutorial? ehbowen Capture, Record, Transfer 5 01-30-2019 09:03 PM
HDMI to USB3.0 capture for OBS Andrew Losurdo Videography: Cameras, TVs and Players 1 11-03-2016 07:45 AM
