11-16-2020, 11:18 AM
MasterBattalion8 MasterBattalion8 is offline
I recently bought a clone ATI 600 capture device with the intent of using it along with my tv-ONE TBC to preserve my rare vhs tapes.
I tested it out on some tapes I had recorded from the early 2000s and they captured the picture just fine, even if the cropping was a bit off.
However the moment I tried to capture a specific tape from the 80s, the picture would only display in black and white and nothing I did could fix it.
Can someone please tell me what I must do to fix it?
11-16-2020, 02:46 PM
So it's just the one tape?
Are you sure it's not B&W?
Are you sure you didn't accidentally change any settings on the TBC?
Is the tape PAL or NTSC, or something else?
12-18-2020, 11:13 AM
Sorry for the exorbitantly long wait. I haven't had time to experiment with my conversion setup in the lead up to Christmas. But so far I think I've established that the colour problem is not with the drive itself, but with the S video cables. They're not connecting properly for some reason and I have to mangle and bend them in awkward ways just to get the picture to display in colour for only a few seconds. Does anyone know of any S video connections that won't have this problem?
12-18-2020, 10:15 PM
Off course, very common problem with S-Video connectors, Replace the cable if the problem exists you will have to open up the VCR and re-solder the S-Video socket legs on the PCB board, I've done a lot of them, some are easy, some are a pain, depends on the VCR model.
12-18-2020, 11:43 PM
Ah, yes, very common. I've done this myself once or twice over the year. The reason it happens is overly using the s-video connection. Push, pull, push, pull. This is why I use s-video extenders now, rarely have to touch the actual VCR in/outs. B&W is a symptom of it being only slightly bad, whereas more often the signal is entirely messed up.
It's usually the connections, not the s-video cable. But the cable is possible.
colour
Hi8 picture is either blinking or black & white? ther89 Capture, Record, Transfer 7 06-20-2020 03:14 AM
Ati AIW X800 black and white picture ofesad Capture, Record, Transfer 1 01-14-2019 01:51 PM
Capture VHS (NTSC) in black and white? marcioteixeira Capture, Record, Transfer 4 03-27-2016 01:51 AM
9800 AIW black & white prob manthing Capture, Record, Transfer 6 06-26-2005 06:48 PM
Why Black & White capture ? Sujit Capture, Record, Transfer 4 05-23-2005 08:27 AM
