02-08-2021, 09:11 PM
gloubu gloubu is offline
I have 2 tapes that I'm having issues with.
Most of my tapes I'm having zero issues with. I have a Windows XP Dell system, VirtubalDub 1.9.11, good Sony VCR and ATI 600 USB. With all that I am getting results shown in the video attached... "tearing"
When I directly plug the VCR into a TV via composite cable. No problem at all, clear image.
Is the capture card having an issue with the tape? Timing issue? Need a TBC for this particular tape?
02-08-2021, 09:58 PM
That's not tearing, It's line timing errors, A good player with line TBC and S-Video out should fix the problem, if not an ES10/15 in the workflow may help fix the problem.
The following users thank latreche34 for this useful post: Kazuya (05-15-2024)
02-08-2021, 11:22 PM
Lack of line TBC is visual issue.
But there are also dropped frames happening, which is lack of frame TBC in the workflow.
Capturing VHS starts with a good VCR (actual "good", not just what a random person thinks is unqualified "good"), which almost always means S-VHS VCR with line TBC. At worst, certain non-TBC S-VHS decks, or some isolated VHS decks, paired with ES10/15.
Avoiding a frame TBC is usually an exercise futility, time wasting by searching. There are some TBC(ish) options, using ES10/15 with a few other devices like DVK, as a budget option (but with quality-lowering side effects not found in actual TBCs).
Hi8 capture workflow with tearing? robotr0n Project Planning, Workflows 6 01-01-2021 03:18 PM
VHS Capture Issue Ryelzz Capture, Record, Transfer 1 09-16-2019 10:25 AM
Strange video tearing effect on portion of VHS capture... bugfixin Restore, Filter, Improve Quality 2 12-16-2018 11:10 AM
Using TBC and video still tearing? jriker1 Restore, Filter, Improve Quality 127 10-06-2016 11:41 AM
Fixing VHS tearing during capture; JVC D-VHS vs. JVC S-VHS VCR? lucgallant Capture, Record, Transfer 10 05-09-2010 07:15 PM
