03-25-2021, 11:35 AM
chrisbati chrisbati is offline
Hi,
I'm trying to use Prores codec in vdub2 but it always crashes.
I attached the crashinfo, but whatever parameter I tried, I always get the same error.
I'm capturing from usb device in pal.
Thanks in advance for help
Chrisbati
03-28-2021, 03:09 PM
Cactus Cactus is offline
I have the same problem, there's something about the FFMPEG ProRes codec in VirtualDub that doesn't work. Use Lagarith or HuffYUV instead - someone more knowledgable than me can specify.
Prores/DnxHD for U-Matic Capture Winsordawson Capture, Record, Transfer 3 07-03-2020 10:16 PM
Interlacing artifacts in ProRes, but not DV codec? babanan Capture, Record, Transfer 9 05-26-2020 04:38 PM
Is there anything wrong with using VirtualDub2? Sirworm Capture, Record, Transfer 4 01-02-2020 03:03 AM
VirtualDub2 vs VirtualDub 1.9 or 1.10. 64 vs 32? ragu0012 Capture, Record, Transfer 1 03-04-2019 12:21 PM
Convert Apple ProRes to lossless Windows Codec? Winsordawson Edit Video, Audio 13 09-08-2015 09:45 AM
