03-12-2022, 02:52 AM
vikinagy97 vikinagy97 is offline
I do not have any DVD recorders yet. So I would like to ask: which is better, a recorder with/without HDD? Which can do the following: capture lossless, then compress?
And which is better: a DVD recorder or a desktop PC with a tuner card and recording software?
03-12-2022, 03:07 AM
thestarswitcher thestarswitcher is offline
DVD recorders should be used as passthrough devices, and then you capture with Virtualdub.
So it's VCR->DVD recorder (if no external TBC is around)->capture card.
DVD recorders can't get lossless, you're stuck with plagued MPEG-2 compression from the baseline.
03-12-2022, 05:35 AM
Can a laptop be powerful enough to run Virtualdub and capture properly? Or should I use a desktop PC? Laptops can also have strong CPUs, can't they? And what Windows version is recommended? I've read somewhere in Digitalfaq that WIN10 is not very good for capturing (I have this and Win8), but how can I get an older version?
compression, dvd, hdd, lossless, recorder
Very rare HD video formats? latreche34 General Discussion 6 04-04-2021 07:15 PM
Capture and compression formats, VHS H.264? jeffpeck Encode, Convert for streaming 1 12-24-2017 11:20 PM
NTSC DVD recorders that accept PAL input, record to PAL DVD? Phthalocyanine Capture, Record, Transfer 0 09-15-2016 10:10 PM
Converting different videotape formats to digital formats? pdalton Capture, Record, Transfer 4 04-26-2016 05:00 AM
DVD VCR recorders that will record copy protected movies? admin Capture, Record, Transfer 0 07-20-2010 12:15 PM
