12-21-2021, 12:54 PM
Alcheman Alcheman is offline
I'm planning to bring a Hitachi VM-E455LA camcorder with a stack of 8mm tapes abroad with me. I'd like to post the videos I take while I'm abroad so I won't be able to bring a VCR or any large tech. I think the ideal solution would be a composite to usb converter, as the camera only has composite outputs (no S-video). The laptop I'm bringing has Windows 10, and it doesn't have a CD drive, so any software would have to be downloadable. Any suggestions?
If necessary, I could bring an old laptop running Windows 7 that has a CD drive if that would be notably easier/simpler. I've also got a raspberry pi if linux is the way to go. Thanks for any help!
12-21-2021, 06:19 PM
I use an IO Data GV-USB2 capture stick. I record video with Virtual Dub 1.9.11, using the Lagarith codec.
Install guide for the GV-USB2 is here:
https://iotku.pw/gvusb2-guide/
This setup works well with Windows 10 21H1. Captured files are about 40gb per hour.
12-27-2021, 03:17 AM
The problem here is you must have some form of TBC, and camera>computer alone will not work.
And is that an ancient Video8 camcorder, not even Hi8? If so, that will be a problem as well.
8mm, camcorder, composite, conversion, windows 10 64bit
Error transferring with Windows 7 Pro machine? Denicio Capture, Record, Transfer 4 04-26-2021 06:00 PM
Transferring with a SVHS camcorder? gregmorency Capture, Record, Transfer 8 04-28-2020 02:24 PM
Convert AVCHD files from Camcorder to Play on Windows Media Player? rocko Encode, Convert for discs 18 07-15-2015 12:16 PM
Transferring home movies from VHS camcorder (A New Beginning!) ErikCalifornia Project Planning, Workflows 16 03-19-2013 03:31 AM
Freezing while transferring live feed from Sony camcorder timjwilson Capture, Record, Transfer 6 08-06-2012 04:10 PM
