03-21-2022, 11:42 AM
Clubberlang Clubberlang is offline
Hey folks. Thanks for all the help thus far. My original plan (actually still intend on geting one if I scale up) was to get an AIW AGP card + Windows XP but I was digging through my electronics and found a Hauppage WinTV-HVR 950 (the non Q version).
I have done some searching on the forum and understand that it may not work in Windows 10. I am willing to dual boot windows 7 on my current machine and give it a go with VirtualDub but before I do this I want to know if this thing gives adequate quality. I understand that it will do MPEG but not AVI. Otherwise I'll just get my AIW. Is there a particular revision number I should be looking for? I am not sure how to check.
Thanks again
03-21-2022, 11:47 AM
Is it? No.
Can it be? Yes.
Hauppauge has a really bad habit of reusing model numbers on cards that aren't at all the same internally. Extra letters and revision numbers don't tell the full story either.
Several manufacturers are crappy this way.
- Elgato didn't/doesn't use models.
- Tevion didn't/doesn't use models.
- Easycap didn't/doesn't use models.
- Pinnacle reuses model numbers for long-lived devices.
- Dazzle reuses model numbers for long-lived devices.
You'll have to crack it open, see what chips are inside.
The AIW is better. Just use it.
The following users thank lordsmurf for this useful post: Clubberlang (03-21-2022)
03-21-2022, 10:35 PM
WadeDV WadeDV is offline
Good evening LS,
Could/would you PM me about this?
Thank you,
WadeDV
Hauppauge WinTV Vs VirtualDub? Hemroid Capture, Record, Transfer 2 10-27-2020 01:42 PM
Inserted frames from Hauppage, not VC500? BarryTheCrab Capture, Record, Transfer 2 06-30-2019 11:09 AM
Hauppage capture card round-up? lordsmurf Capture, Record, Transfer 3 03-27-2017 05:21 PM
Help with Panasonic and Hauppage workflow. via Email or PM Project Planning, Workflows 13 01-07-2013 11:15 PM
