01-16-2023, 06:25 PM
Emde Emde is offline
Hi all:
I'm about to start capturing around 50 family VHS tapes and have everything working with Virtualdub + HuffYUV. I'm now considering using FFV1/ffmpeg instead to save space. I decided to start testing and can not for the life of me find where to download the plugins for Virtualdub. All of the links I have found are outdated.
A few questions...
1. Is FFV1 better for archiving original lossless video vs HuffYUV?
2. Any tips on where I can download the plugin files for FFV1?
3. At some point I will be editing video in Final Cut. As both of these codecs are natively functional on the Mac, any other options I should be looking at?
Thanks!
01-16-2023, 08:28 PM
stymie stymie is offline
You might try Virtualdub2. It has plugin support for FFV1 (...custom made (based on FFMPEG) with basic options). Also, you could try to create an external encoder within Virtualdub.
01-16-2023, 08:57 PM
traal traal is offline
You can download the ffv1 codec from here: https://www.videohelp.com/software/ffdshow
Setting up VirtualDub with Huffyuv? NotsafeforNick Capture, Record, Transfer 4 08-02-2022 07:59 AM
Ffmpeg, VirtualDub alternative Hackerpcs Capture, Record, Transfer 0 08-01-2020 07:33 PM
FFMPEG, AviSynth, VirtualDub - Which tool for which purpose? naripeddi Restore, Filter, Improve Quality 2 07-05-2018 02:18 AM
Best VHS and Umatic capture workflow with VirtualDub to FFV1? JohnR2 Capture, Record, Transfer 10 03-20-2018 07:22 PM
Problem converting to Huffyuv codec using ffmpeg metaleonid Encode, Convert for discs 3 11-19-2012 07:28 AM
