01-29-2023, 06:36 PM
Duxa Duxa is offline
Trying to capture some VHS via virtualdub. It seems like whenever there is some signal loss due to 1 to 2 seconds of blank tape in between segments virtualdub does some frame dropping and inserting. Which is ok I guess, but there are parts of the video with glitches, and if its a panning shot I think its inserting frames making pan appear stuttered. Id rather the video to look glitchy as it is, rather than stuttery.
So if I untick drop/insert frames under timing options, and select to sync audio via resampling at slowed/faster rate. Is there any downside to doing this? Or another way to put it. What would be the upside of inserting/dropping frames other than audio sync (since the resampling of audio should take care of sync issues)?
Side question that is sort of related. But how does Virtuadub know if audio is out of sync? It has no idea whats being shown and if audio matches.
dropping frames, frames, inserting frames, sync
Audio-video desyncing due to insert frames? NostalgicDrew Capture, Record, Transfer 6 01-30-2022 06:20 PM
Unable to capture lossless without heavy amount of drop frames (Umatic) SHGMC_2 Capture, Record, Transfer 10 11-11-2021 07:41 AM
Automatically drop frames during empty Hi8 tape? EmielBoss Capture, Record, Transfer 5 04-04-2021 05:47 AM
VCR not allowing tape insert? Dukesilver Video Hardware Repair 1 09-19-2020 06:00 AM
Faulty TBC issue? AVT-8710 insert frames? jt_retro Capture, Record, Transfer 27 05-25-2017 09:06 AM
