07-11-2023, 10:56 PM
aramkolt aramkolt is offline
I am trying to decide between these for standard analog to digital VHS conversions:
9000 64MB with DVI port - Says AGP 2x/4x - will this cause problems with an AGP 8x Motherboard slot?
9800 128MB with DVI port - AGP 8x
The 9800 is much more expensive and has more ram, but I am not sure if it actually produces better results?
The motherboard I plan to use it with is an Asrock P4V88+ which says it has an AGP 8x slot. Not sure if the 9000's 2x/4x spec will decrease performance for our use case, or if it has issues working in an AGP 8x motherboard slot?
If there's a better variant to look for that doesn't require impossible to find breakout cables that I should be looking for instead?
Is the purple "Domino" input cable the same as the non-domino/solid purples one in terms of pinout/interchangeability?
Thank you in advance!
07-11-2023, 11:02 PM
Get 9000. For video capture, no difference in 9000 and 9800.
DVI output models lack need for special cables, like 9600.
Yes, domino = purple.
Tip: domino usually nasty, harder to clean, white yellows. So get purple.
Is regular s-video cable as good as Monster cable? ThumperStrauss Capture, Record, Transfer 6 01-03-2022 05:31 AM
ATI AIW list of cards complete? x800 cards good? Amaze Capture, Record, Transfer 4 01-02-2016 02:55 PM
ATI Dongles - Purple and Otherwise Joekster Capture, Record, Transfer 7 01-31-2015 07:02 AM
How to split cable TV and cable internet coax for two rooms ? stoogedog Computers 6 12-05-2006 06:15 AM
Purple band on AIW TV and Captures Jerome Capture, Record, Transfer 12 04-30-2005 09:06 AM
