05-08-2024, 08:56 PM
ThumperStrauss ThumperStrauss is offline
How is the AmarecTV capture software is able to yield synchronized video. I know it is inserting and dropping frames here and there. I think most people miss these if they blink. But they don't miss when the audio and video is out of sync.
1. Is there is a way in AmarecTV to see how many frames were inserted or dropped?
2. What settings in the timings screen in VirtualDub 1.9.11 would mimic the way AmarecTV prioritizes audio-video sync above all else? I know that LS said: "DO NOT disable frame drops/inserts. All that accomplishes is essentially disabling drop reporting, and prevent inserts to fight off audio skew." But how come VirtualDub doesn't see to fight off audio skew as well as AmarecTV? What could be going on?
05-08-2024, 10:59 PM
Yes. On the Advanced tab, tick "Make a report file" and after each capture, a TXT file report will show a log line each frame captured. Look for "Total", which will indicate where a drop or insert occurred.
You can also spot them with VDub: on the Go menu, "Next" or "Prev" dropped frame.
The following users thank Hushpower for this useful post: ThumperStrauss (05-09-2024)
AmaRecTV frame inserts, frame drops, audio desync? FleshWound Capture, Record, Transfer 16 03-28-2026 06:35 AM
GV-USB2, AmaRecTV dropping frames, no VirtualDub audio? MrEightThreeOne Capture, Record, Transfer 14 03-25-2025 11:27 PM
Video/audio works in AmarecTV, but not in VirtualDub? lijeu Capture, Record, Transfer 15 12-31-2020 10:29 AM
AmarecTV won't capture audio from USB-Live2? koberulz Capture, Record, Transfer 8 07-31-2020 09:29 PM
VirtualDub audio skew correction with Direct Stream Copy? a2dconverterguy Edit Video, Audio 2 06-02-2018 11:32 PM
