Hi, thanks for the comprehensive reply. To answer some questions in random order
If it's 32-bit, then that laptop is not properly set up. Where did you get that?
I bought it on ebay. It did have win10 installed but the seller said they'd install win7 me before they sent it. When I right click on 'computer' and choose properties it tells me
Installed Memory (RAM): 8.00 GB (3.17 usable)
System Type: 32-bit OS
It's a not genuine 'Build 7601' copy of Windows. Does this matter? Should I buy an activation key? Or just buy a new Windows7 OS with key and install everything fresh? If so, is Home Basic good enough or should I get an higher spec OS?
But failing to start is odd, and in fact I don't recall ever seeing this happen.
Sorry, maybe I didn't explain myself clearly...
VirtualDub will load. I get lots of 'Bad Image' messages for .vdf plugins before it opens. But it does open.
Try to use the hofmand installer
I gave this a try...
github scares me... I never know what I'm looking at there.
The thread linked says to download the .msi file but I can't see that anywhere in the folders on github. I navigate to sources and can see
huffyuv-2.1.1.zip so I've downloaded that.
When opened I get a
huffyuv.dll and huffyuv.inf file.
Right clicking on either doesn't give an option to 'install' in the drop-down menu... like the other huffYUV.inf files do.
Doubleclicking on the .inf file opens a notepad text document.
Doubleclicking the .dll file I get prompted to tell the computer which program I want to run the .dll with. I nagivate to
VirtualDub.exe and select. This then begins the process of opening VD; once past the .vdf plug-in error messages I get:
'VirtualDub Error' message:
The file "c:\Users\Dell\AppData\Local\Temp\Temp1_huffyu v-2.1.1.zip\huffyuv.dll" is of an unknown or unsupported file type.
At this point I'm wondering if my file locations many need organising? Is there specific locations needed for VD, HuffYUV, crossbar, for everything to work together? I guess this is one of the things I'm struggling with coming from a Mac. Mac OS seems to put everything in the correct place during install. VD being run from a .exe I'm not sure if the ancillary bits can find it.
But as you say, HuffYUV isn't needed for the purpose selecting a video source so I'm getting ahead of myself focusing on HuffYUV right now.
I need to work out how to get VD to let me select a video source, right now this option is blank, not even showing composite option. This
seems to be the domain of the Crossbar Thing?
So to go over it once more, here's how I'm using Crossbar Thing:
+ Pinnacle 710 is plugged in.
+ I run the Crossbar Thing.exe.
This opens a window which gives me three options on the left to select from
Pinnacle 710-USB Crossbar
Integrated Webcam
Pinnacle 710-USB
On the right is two buttons; 'Enumerate the loathed crossbars' & 'Open selected crossbars'.
Highlighting anything and clicking 'Enumerate the loathed crossbars' doesn't seem to do anthing.
When I highlight 'Pinnacle 710-USB Crossbar' and click 'Open Selected Crossbar' I get a properties window open where I can select Input & Output. I choose 'Video SVideo In' for the Input and click Apply & OK.
When I highlight 'Pinnacle 710-USB' and click 'Open Selected Crossbar' I get a properties window open with tabs along the top for; Pinnacle / Video Extensions / Audio Extensions / Video Decoder / Video Proc Amp.
Which combination should I be choosing?
Low-quality Easycap garbage,
I was only using the old Roxio to see if VirtualDub would receive a signal from it. It does. So I know the VCR is working, I know that VirtualDub accepts and shows a signal (from Roxio) and I can select S-Video as source (when Roxio plugged in). I know the laptop sees the 710-USB because it disappears from Crossbar Thing and VirtualDub when not plugged in. So the problem really is getting VirtualDub to let me select a video source.
Could this be because the driver isn't loading into VD? Would VD let me select the 710-USB even if the driver wasn't right?
I have both PCLEUSBx32.exe and Pinnacle_Video_Driver_64bit.exe downloaded. I tried running both. Are they interfering with each other? When I run the PCLEUSBx32 I choose Pinnacle Systems 5xx/7xx and click 'Next' (other options being 'Dazzle DVC 130/170' & 'Dazzle DVC90/DVC100').
When I enter Device Manager and select System Devices I see 'Pinnacle Marvin Bus'. I right click properties and is says device is working properly / version 2.1.29.0 / date 2006 and that it's located in system32\DRIVERS\MarvinBus.sys
I should note again that I don't think I have the SysWOW folder on my OS.
That's probably all the info I have right now. If you have any more ideas on how to get VD to let me select S-Video as a source I'd be super grateful.
Thanks again
