02-18-2025, 12:51 PM
Originally Posted by aramkolt View Post
The problem you'll probably run into is that the incoming SDI probably already needs to be 480i which your graphics card is unlikely to support as an output over HDMI. I can't comment for sure since I don't own one. What the D4E definitely lacks is a proc amp,
This is why I suggested a capable media player so he can set 480i and also adjust the proc amp and audio gain as well.
02-18-2025, 01:35 PM
witchingseasonfilms witchingseasonfilms is offline
Originally Posted by latreche34 View Post
No, computer does not produce a compatible frame even via HDMI, Computer resolutions and video resolutions don't get along, this is a known fact for decades, Ask Lordsmurf he's been around, he will tell you.
What media player or device would you suggest for writing digital content to VHS tapes using your method?
02-18-2025, 02:03 PM
The problem you'll probably run into is that the incoming SDI probably already needs to be 480i which your graphics card is unlikely to support as an output over HDMI. I can't comment for sure since I don't own one. What the D4E definitely lacks is a proc amp, so you can't fine tune luma/chroma levels like you can with the brighteye, though to really benefit from that, you'll need an analog waveform monitor/vectorscope to check output levels of the analog conversion. What I suggested with the 3G monitor will output 480i over SDI assuming it is in a davinci timeline that is set to 480i and davinci will do the downscaling.
Gotcha. In theory, wouldn't the 3G monitor paired with the D4E outputting from a 480i Davinci timeline do the same thing? Aside from the hardware proc amp.
Appreciate the link to the Brighteye hardware, too! I'll look into the 11-HD a bit more.
Thank you all for your insight on this.
Recording digital to VHS? (Not VHS to digital!) hotphaser Edit Video, Audio 5 10-29-2024 11:01 PM
VHS to digital produces green lines recording? AFGIV Capture, Record, Transfer 5 09-26-2023 08:13 PM
Grey screen when recording tape? NostalgicDrew Capture, Record, Transfer 4 12-31-2021 02:35 AM
Digital to analogue for VCR recording? jayclay Capture, Record, Transfer 10 09-02-2020 05:16 AM
Scrambled recording on a D8/Hi8 tape? knumag Capture, Record, Transfer 9 06-03-2014 03:05 PM
