06-09-2025, 02:15 PM
DeePeeGee DeePeeGee is offline
I've seen it brought up a couple times but no real definitive answer if the ATI AIW captures VHS better than LHi. I think LS mentioned that AIW was the best made for VHS capture but has anyone done any comparasons? What makes the AIW better for VHS capture than an AJA LHi/e? Back in the day it was cost prohivitive but now you can garb the LHi and run it on a modern system for around $100 second hand. Is AIW > LHi/e settled agreed on fact?
Maybe LS can chime in with some details / depth on why the AIW is better than a more modern LHi/e?
Thoughts?
06-22-2025, 07:26 AM
DarrylInCanada DarrylInCanada is offline
I have no comparison to share. From what I’ve read, AJA is excellent. It captures in uncompressed so will need more HDD space. While AJA was designed for broadcast quality footage, I haven’t read that it struggles with consumer VHS or home movies. Bottom line, if I found one for $50 to $100, with the breakout cable, I would definitely buy it.
AJA Kona LHI noise, fan replacement? srmusico Video Hardware Repair 3 01-02-2025 05:35 PM
AJA Kona LHi video won't show? bstegner Capture, Record, Transfer 16 01-23-2024 02:46 PM
Aja Kona Lhi best codec waloshin Capture, Record, Transfer 1 01-16-2021 11:49 PM
Vhs capture --- kona aja lhi ... Not impressed!! johnnysh Capture, Record, Transfer 3 03-21-2020 02:17 PM
Kona LHi dropping frames from VCR with TBC? ryan42 Capture, Record, Transfer 6 06-25-2018 03:27 PM
