04-08-2026, 01:51 PM
That may work fine, $50 is fair.
I will today share a sample with exact same trouble as Usb 710/510
On a Film "What dreams may come" - "Куда Приводят Мечты" (Russian Title)
Released on 2000
I saw the full model DMR E55-EP.
I didn’t saw any info about EP. But I sure it got a TBC.
Well, i also found an EE verison, he is cheap but shipping time is awaiting me...
04-09-2026, 01:32 AM
Letters at the end often (but not always) mean things like market/country codes, or even color codes.
So EE, EP, may be the same internals.
May.
04-09-2026, 04:27 AM
May.
Well, I got other question unrelated to this but very important, how I could make a sound work from Sony HandyCam when it got only an S-Video and Av (as Jack 3.5mm cable)
I tried to connect AV to sound and it just doesn’t work.
May.
I think i will spend a more money but will have a better TBC.
04-09-2026, 04:58 PM
Make sure your AV output cable is correct. Most Sony and Canon camcorders are the same, but many other devices use a different pin out. Here’s a diagram of the correct cable pin out:
https://pinoutguide.com/DigitalCamer...e_pinout.shtml
BW
04-10-2026, 07:09 AM
Originally Posted by BW37
Well, i found the model what i got CCD-TR718E/NP-F330 (Pal/NTSC)
04-10-2026, 12:41 PM
TBH, video and mono are hard to find but i will try.
I figured out how to force it work with a stereo AV cable.
04-11-2026, 10:36 AM
Yes, any stereo audio adapter cable, 3.5mm TRS to dual RCA, should work. The wires and connections are the same, just the connector colors are different. This should give you the composite video and mono audio out of the camcorder. But always better to use the s-video for the video and just the one RCA connector for the audio.
Good Luck!
BW
04-11-2026, 12:57 PM
I for sound make a mono vcr passthrough (Which is LG cc290tw)
04-12-2026, 03:37 AM
top problem is the lack of tbc.
04-13-2026, 02:16 AM
I already knew about this, im struggling
Good Luck!
BW
Im using S-Video on purpose to get the best quality as i could but chroma shift is suck
