03-14-2006, 07:25 PM
Well, there's nothing special about a "DVD" settings that cannot be done in the generic MPEG settings. Read through the DVD settings (in advanced view) and remember them, write them down. Then start a generic MPEG and plug in those values, only now you can change whatever you want, like bitrate and resolution.
And when testing, don't encode more than 5 minutes worth of footage. Don't try to do 1-2 hours or anything like that.
03-15-2006, 10:57 AM
lookouts lookouts is offline
Aha! Thanks.
Different video size, despite same resolution? pumapuma Capture, Record, Transfer 2 07-18-2016 01:46 PM
Cropping and resolution in Handbrake, which is right? Turmoil Edit Video, Audio 5 07-14-2016 05:12 PM
Captured PAL VHS - Outputting to DVD - What Resolution Should I use? BayAreaSean Encode, Convert for discs 4 04-29-2016 11:13 AM
Are PAL DVDs better than NTSC resolution? premiumcapture General Discussion 2 07-23-2014 05:06 AM
ATI MMC and 704/720 resolution thoughts? admin Capture, Record, Transfer 0 02-15-2005 09:19 AM
